Datum call-out on tangency of two radii...
Imagine a number eight lying sideways. I want to establish the two points of contact as the datum. I have a part that has this contour on one side and I would like to establish those two points of contact as the horizontal axis.
How or what is the best way to establish this datum?
RE: Datum call-out on tangency of two radii...
Make sure that the datum targets noted can be located or set up by Production and Quality. The example in the ASME standard reflects a 45 degree V or linear distance between the points that CAN be located on coordinate measuring equipment.
Hope this helps.
DED
