How do I get Material hatch to appear in section view?
I've copied the material library to our server and edited some of the hatch styles. However, when amaterial is applied to a part, the hatch style does not appear in the 2D section view.
Is there a setting somewhere?
RE: How do I get Material hatch to appear in section view?
Check the Default ISO or ANSI standard. it will work.
Edit your Drawing standard file.
I double click on the applied material in the specification tree and it shows the hatch style that I desire (I edited the aluminum hatch pattern). However, the section view shows it as a default pattern... not even the out of box aluminum pattern.
How do I fix this?
if not have a look at + View + Generation + Material Cut Pattern in your Standard. It should be set to Material.
I created a new drawing without the existing drawing and I still do not get the correct pattern.
Have you tried to edited an existing pattern as mentioned above? Do they shown in your section views?
does it work if you staart a new drawing from a really new file using your standard ?
