what about this video card
Hi All,
I think it's time for an video card update with more memory for use with ProE. I am looking at this card Sapphire Radeon X1300 - 512DDR2, V/D/T, PCIx. The price looks fine ($125.00 CDN).
I have a 20" DELL flat screen and 2.6GHz AMD Athlon, is this card compatible with ProE 2001?
Does anyone one out there have any experience or complaints with this card.
Thanks for any info you can provide
Tofflemire
Tofflemire
RE: what about this video card
Here is the link to PTC's supported plateforms http:/
Pro/E 2001 - http://www.ptc.com/WCMS/files/32351en_file1.pdf
WF2 - http://www.ptc.com/WCMS/files/30892en_file1.pdf
WF3 - http://www.ptc.com/WCMS/files/30874en_file1.pdf
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
Just remember that if you start seeing graphic problems or weird crashes, PTC won't help you.
Ben Loosli
Sr IS Technologist
L-3 Communications
I currently have a Radeon 9000 Atlantis Pro (128Megs memory). I am noticing some graphic problems, but only when I have large assemblies open. I was thinking that I need more Graphic Memory so that is why I ask about the 512 Memory card.
I have not had any crashes using the 9000 card.
Tofflemire
