Residual connected CTs and VTs
Anyone pl. explain the pros and cons of residual connected current and voltage transformers to detect earth faults.
Advanced thanks...
Advanced thanks...
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Residual connected CTs and VTs
I know residual connected CTs will be used for detecting solid ground system earth faults and CBCT will be used for detecting high resistance ground system earth faults. I would like to know the advantage of using residual connected VTs for detecting earth fault.If any specific advantage, pl. explain me
Thanking you.
Zero sequence voltage says there is a ground fault somewhere, zero sequence current says that the fault current is flowing through the measuring point.
