eDrawings 2006 hidden part options
In SW 2005 when I saved as an edrawings file none of the hidden parts in my assembly were shown in the edrawings viewer. In SW 2006 every single hidden file is carried over to the eDrawings viewer which is not desirable. Where is the option to de-select all hidden files so they will not be exported to eDrawings?
RE: eDrawings 2006 hidden part options
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Second point ... you did not need to create a second assy. You could have created a config of the main assy with the "offending" parts suppressed. But you should not have had to create either.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Strange that hidden parts are showing up in the eDrawing file as hidden--since they are able to be viewed within eDrawings by right-clicking and selecting Show Part. I don't remember this happening previously. Bloats the file size, too.
Anyone else seeing this?
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
