Inspections techniques for estimate bearings conditions
I would like to know typical techniques to verify operation of installed bearings (Temperature, missaligment,etc).
Orangel Roca
Orangel Roca
RE: Inspections techniques for estimate bearings conditions
Vibration can also to some extent identify bearing stressors (unbalance, misalignment)
Temperature is a good indicator of the lubrication performance.
Oil analysis can provide some information on condition of oil-lubricated bearings (for example, wear particle content).
In some cases bearing clearance can be measured while shutdown. Plastigage measurement of bearing clearance in sleeve bearings. In limited cases measurement of shaft movement can be used to provide some indication of bearing clearance.
