Adding multitasking to the make file
Hello
I wish to add a filter to my SimuLink model, and so have added a discrete filter block along with two rate transition blocks either side of it. (A Fast to slow in front, and a slow to fast after)
When I tried to build the model, I got an error saying that Multitasking mode wasn't enabled. So I went to Tools/Real-Time Workshop/Options and set the mode to multitasking in the Solver tab.
Now when try to build it says I need to enable multitasking in the make file. The help file says that adding the token |>MULTITASKING<| in the appropriate place in the make file will achieve this. However, even after doing this I get the same error message.
What do I need to do enable this mulittasking mode?
Thanks very much for any guidance!
Jimbo
Jimbo
