compaction of sand/other after placed as slurry
How do you normally compact sand, sand/silt or gravel after it is placed from dredging as a slurry.  Thanks,
RE: compaction of sand/other after placed as slurry
Not much info given Kivi. Factors to consider may be access, depth of fill, material gradation, water content, desired result, etc..
One method I've used and seen done before is Deep Dynamic Compaction (DDC). This is the simple brute force method of dropping large weights (10 to 30 ton) from a crane in a grid type pattern to cover the site and densify the soils down to 20 or 30-ft. Simple but it works and is not too costly.
Kivi have you tried explosive compaction.
http://www.explosivecompaction.com/Pages/explosive_compaction.htm
INCO has used this at its Sudbury site and there were some papers on in in CIM Journal for late 2000.  UK MIRO also has some papers on this.  If this is dredge product rather than spigotted tailings you may want to dry it first as the clay content will certainly affect "squeezability"
I thought that sand had the best compaction..but I'm just a girl, what do I know..
Vibrocompaction could also be considered.  It is usually a more controlled method and seems to work better with high groundwater levels.
