Modicon Momentum 170ARM37030 Help
I've programmed other brands of PLCs but I'm a newby at Modicon. Can anyone shed some light or point me in the right direction on how the addressing for your symbols relate to the I/O terminals? I'm using proworx32 by the way. Most of the plcs I've worked with use X or Y, or at least have a table where you can assign inputs and outputs. I can't seem to find a good beginner resource on modicon. I know this should be simple stuff but I just need a few examples. I've tried modicon.com (Telemecanique)
Thanks!
Thanks!
RE: Modicon Momentum 170ARM37030 Help
