Placing Library Feature
Good afternoon, I have a library feature which I use to put a flow stamp on a cylinder. It works pretty good if you turn off the dim from the end of the sketch to the edge of the part. It keeps erroring out when that dim is not suppressed, it can not find the cylinder edge and I have to manually install that dim now. Any suggestions on how I could get that distance to work automatically? Thank you in advance for any assistance.
RE: Placing Library Feature
Is the cylinder edge a silhouette edge, or round end-face edge or ???
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Can you post the feature file for those interested to investigate? See FAQ559-1177
http://www.savefile.com/files/4061919
I included a copy of the library file and a sample dumby part. The distance in the library stamp has been suspended, in order to make it work. Thank you again for the help and I am using SW2006sp3.0.
SP3.1
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
To view the file you must Download the codec from:
http://download.techsmith.com/tscc/tscc.exe
Maybe that will help you understand my process.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
