Concrete Joints on Basement Walls
I have a 27 ft x 50 ft x 9 ft deep basement. How often and at what locations we need to provide joints to avoid future cracks. The walls are 12" thick.
Concrete Joints on Basement WallsConcrete Joints on Basement Walls(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Concrete Joints on Basement Walls
For a 50' wall - not sure I'd use any joints and if the concrete cracks, patch or inject the crack and provide waterproofing on the outside....or ignore the crack and just waterproof the wall which is what most often happens.
For a cold climate, use 2" thick 4 ft wide extruded polystyrene boards lengthwise, up to the bottom of the siding. Attach with an exterior adhesive sold by the PS vendor. Use metal flashing from under the siding to over the polystyrene, & paint any remaining exposed PS to protect from sunlight. I suggest also using 1" thick PS insulation below the 2".
The exterior insulation is far superior than applying inside -- protects the concrete (I have seen frost on inside of concrete behind a 'finished' basement wall in Wisconsin), saves space & avoids fire hazard (although can use fiberglass inside, it has a lower R value).
So, I consider the root cause to be insufficient drainage alongside the basement wall. The drain tile was typically covered with about a foot of crushed stone, then the remaining excavated area was filled with soil for growing shrubbery, flowers, etc.
My idea for improved drainage: Place a cardboard partition in the excavation, about parallel to and the height of the basement wall. Then backfill inside with crushed stone or sand/gravel, and outside with soil. So full height drainage. Perhaps cant the cardboard so as to have the width of the drainage region widest at the bottom.
Would this be a good idea? Has anyone done similarly?
I’m a bridge guy, but for drainage behind foundation walls in bridge applications we do something similar…we use a felt like fabric (we call it filter fabric) to separate the drainage stone from the rest of the backfill. This keeps the fines from the backfill from clogging the drainage stone. For placing the backfill I’ve seen bridge contractors place steel plates vertically to separate the two types of backfill and then pull the steel sheets once he’s backfilled the full height of the wall.
We usually bring the drainage stone to 1’ or so below finished grade and wrap the top surface with the filter fabric. They we place top soil and grass.
