GRIP to create points
I'm looking for a compiled grip programm for creating points from an ascii file (3 coordinates on each line).
Thanks in advance
Thanks in advance
RE: GRIP to create points
Use a GRIP program found in the International GRIP Library named: 'FILE2POINTS.GRS' (source code file). If you need it compiled for you, I'm sure something can be arranged....
SS
thanks for your answer, I found the file2points.grx directly and was able to test it.
But this programm read a file formatted like:
x1
y1
z1
x2
y2
z2
And my input file is formatted like:
x1 y1 z1
x2 y2 z2
Thanks in advance
You can define a spline by points (from file) delimited as you have described (one x y z point per line separated by spaces). So, create a spline using points from your file, then create a point set on the defining points, and delete the spline.
Maybe someday we will be able to import points from file directly in the point set command (makes sense to me, anyway).
Just a problem, my file containt about 1500 points !!!
Thank's anyway
I will try and gave you a feedback
Didier
I wrote this to read a 3-D scan file from a Mitutoyo 3D cmm-machine .Maybe it can help . Enjoy .
$$ SUBROUTINE :Read_cmm_points.GRS
$$ FUNCTIE: Programma leest 3-D punten van een aangeduide scan-file van
$$ een Mitutoyo 3-D meetmachine en zet deze modelling op het
$$ scherm in de vorm van punten.
$$ GEBRUIKTE BESTANDEN : aangeduide scan-file.dat
$$ Example input file format :
$$ #00:GEOPAK-WIN Scanning
$$ #02:kanaal_A
$$ #04:ZX(Y)
$$ #05:Cls
$$ #06:MM
$$ #12: -57.36521 110.27753 -64.24180 0.00112 0.00000 -1.00000
$$ #12: -57.36471 110.32947 -64.24111 0.00135 0.00000 -1.00000
$$ #12: -57.36521 110.38151 -64.24141 0.00161 0.00000 -1.00000
$$ #12: -57.36421 110.43046 -64.24122 -0.00016 0.00000 -1.00000
$$ #12: -57.36472 110.48066 -64.24053 -0.00056 0.00000 -1.00000
$$ #12: -57.36472 110.53987 -64.24131 0.00004 0.00000 -1.00000
$$ #12: -57.36472 110.59114 -64.24211 -0.00158 0.00000 -1.00000
$$ #12: -57.36522 110.65192 -64.24140 0.00006 0.00000 -1.00000
$$ #12: -57.36522 110.70269 -64.24170 -0.00155 0.00000 -1.00000
$$ #12: -57.36473 110.76114 -64.24200 0.00143 0.00000 -1.00000
$$ #12: -57.36473 110.81561 -64.24129 -0.00009 0.00000 -1.00000
$$ #12: -57.36523 110.87476 -64.24058 0.00149 0.00000 -1.00000
$$ #12: -57.36423 110.92300 -64.24038 -0.00164 0.00000 -1.00000
$$ #12: -57.36524 110.97405 -64.24019 -0.00162 0.00000 -1.00000
$$ #12: -57.36474 111.03577 -64.23947 -0.00001 0.00000 -1.00000
$$ #12: -57.36523 111.08461 -64.23926 -0.00309 0.00000 -1.00000
$$ #12: -57.36525 111.14470 -64.23956 -0.00004 0.00000 -1.00000
NUMBER/SRESP,aantal,xyz(3),xpunt,ypunt,zpunt
STRING/cmmfile(80),lijn(132)
ENTITY/PNTS(10000)
DATA/cmmfile,'PUNTEN.DAT'
st1:
TEXT/'Geef file naam (vb : P:\BLE\PUNTEN.DAT)',cmmfile,RESP,DEFLT
JUMP/STOP:,STOP:,RESP
IF/LENF(cmmfile)==0,JUMP/ST1:
FHREAD/cmmfile,IFERR,FILERR:
JUMP/next:
FILERR:
MESSG/'File niet gevonden'
JUMP/ST1:
next:
fhread/cmmfile,iferr,filerr:
fetch/txt,2,cmmfile
reset/2
aantal = 1
loop_3:
read/2,ifend,eof_3:,lijn
ifthen/substr(lijn,1,4)=='#12:'
xpunt = valf(substr(lijn,5,14))
ypunt = valf(substr(lijn,17,14))
zpunt = valf(substr(lijn,30,14))
point/xpunt,ypunt,zpunt
aantal = aantal + 1
endif
jump/loop_3:
eof_3:
fterm/txt,2
print/ 'Aantal gelezen punten '+ istr(aantal)
STOP: HALT
x1,y1,z1
x2,y2,z2
xn,yn,zn
So, I think if you edit your file to use commas as the separator (an automatic find and replace function will make this easy) you should be good to go.
