partial revolved section cut in NX3
I want to make a revolved section cut at a given angle, but only one branche.
In NX1 this was fairly easy: pick a rotation point in the parent view (e.g. centerpoint of a cilindrical shape) and then define a cut position. You then could leave the menu and place the view without having to select the second branch at the other side of the centerpoint. Afterwards you could easely change the arrow positions to narrow down your section area.
I have been trying to do this in NX3 and I can't find a way. After you select the parent view the 2 branches are already visibel and the first rotates with the mouse as soon as you have selected a center point. After selecting a cut position for the first branch you must choose one for the second. Doing this and editing the section lines afterwards (e.g. deleting the 2nd) will show an error.
What did I miss?
What did I miss?
RE: partial revolved section cut in NX3
Are you trying to create a section cut at a given angle but prevent the section from going completely through the rotation point to the other side of your part?
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Get out of the Add Section View mode & then right click on the section line arrowhead that you wish to relocate & pick Edit from the MB3 pulldown. Select the arrowhead again & use the Point Constructor to move the arrowhead to the center (or wherever you want it to stop short). Hit Apply or OK then update your views. No errors for me.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Thanks for your intrest.
The solution you mention is a posibility. The only problem is that the projection angle of the section view is changed if the angle of the section changes. For simplicity we want all our section views to stand "upright". In your solution the view is projected perpendicular to the hing line (as it should according to standard rules, but we don't work like that).
Now I have to edit the view and change the rotation angle manualy. In NX1 this was completely associative when using a revolved section cut.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
The purpose of a draft is to communicate production information to the people involved. This must be tailored to their needs and their level of education should be taken into account.
Drafting standards are very straight forward to people who understand projections and they should be used when communicating with customers and suppliers.
The people we have to work with have little education if any at all. The drafts help them in positioning the right things on the right place. We try to keep our drafts as simple as possible.
I consider a high-end CAD system a system that allows for maximum flexibility with minimal user input. This includes "cheating" on official standards to make your own.
So with all of that said, UGS is supposed to create drafting commands for every type of non-standard situation just so you don't have to spend 30 seconds manually setting a view angle? Sorry, but that isn't going to happen. NX would end up having 20 different types of section views and NX would be such a bloated & expensive software that no one could afford to buy it or learn to use it quickly....and something tells me that's why you're allowed to change the view angle in the first place....so you CAN deviate from drafting standards.
Don't get me wrong, I completely understand what your complaint is & I do empathize with you, but UGS isn't going to tailor their software to meet every single drafting situation, no matter what you consider high end. I don't say that to be rude or mean...that's just the way it is.
I would suggest that if you really think you have a good argument that the software is not functioning AS INTENDED, then you should call GTAC at (800)955-0000 and tell them about it. Note that "as intended" probably will not include your situation, because NX is not intended to be used for creating shop docs as much as it is to create drawings/blueprints. I should also forewarn you that after being a UG user for close to 10 years, the "high end" CAD argument goes about as far with UGS as I can kick my monitor in bare feet.
Sorry no one can give you exactly what you want, but that's pretty typical in the CAD world & especially with NX. I hope the suggestions we did give you help out in some fashion.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
