Very Short Slotted Connection
We have a set of shop drawings that came in where every connection, every one, has a 13/16" x 1" horizontal slot at each bolt. The project involves numerous independent column/beam/column segments that span across areas where adjacent bearing walls are terminated.
We called for A325N (bearing) connections so the slots were a surprise. We were told that this is just a field tolerance thing, that its no big deal and that it is a common practice.
But I've never seen a case where a fabricator, on their own initiative, simply used slots at every bolt without notifying the engineer.
Do you see these very short slots used in straight-up bearing connections in your own practice?
RE: Very Short Slotted Connection
If they were slip critical to begin with then yes the strength would decrease with the slot.
I know I'd never do it at a brace, but even at other connections it seems wrong.
