carbon equivalent
carbon equivalent
What is the minimum value for Carbon equivalent for ASTM A105 foged fittings?
RE: carbon equivalent
The formula is as follows;
CE = C + Mn/6 + (Cr+Mo+V)/5 + (Ni+Cu)/15
All elements are expressed in weight percent amounts.
I agree with standweld that there is no defined minimum CE value for A105. The maximum CE value should be your controlled parameter.
Please advise me about your specific application to control the minimum CE value.
