Internal Coating Failures in Deaerator Towers
Fluid: Seawater
Capacity: 46,000 bpd
The water Injection System consist of a Deaerator Tower, Coarse and Fine Filters. In the past we have been using glass flake lining and Monel/Super Duplex Stainless Steel internals. However, we are experiencing repeated failure of glass flake lining and epoxy coating in this service (3rd time now).
We have heard different versions from Vendors, some saying that the internal coatings have been successfully used in other project and that it is strange failures should only be with us.
Can someone please share their experience?
Will SDSS cladded vessels be the best solution?
Thanks.
Fluid: Seawater
Thanks.
RE: Internal Coating Failures in Deaerator Towers
My experience is with chopped glass fiber-reinforced resins requiring greater chemical resistance, so can only share some general observations:
Epoxy resins vary greatly in resistance to water permeation. Glass flake increases the resistance, so maybe someone thought that a less expensive resin would work. A more expensive vinyl ester resin will have greater chemical, moisture & temperature resistance than a polyester. Is steam used in the deaeration?
Consider one of these based upon your conditions:
h
Also, it is important to have a sufficiently thick topcoating separating the liquid from the glass. Any sand abrasion?
Steve Jones
http://www.pdo.co.om/pdo/
