General Densities of different commonly used civil engineering fill ma
Could someone direct me to a nice source on the web that realtes soil, crushed rock, drain rock, riprap, sand.... cubic yardage to weight or ton.  This would be the density of common civil engineering type fills.
RE: General Densities of different commonly used civil engineering fill ma
circle4k,
There is likely too much variation depending on moisture content, gradation and dry unit weight at various degrees of compaction to make such a useful and accurate general reference for non-soil materials. I suggest that you can make an educated guess or better still datamine your own field/lab data on historical projects to come up with typical ranges.
Jeff
Jeffrey T. Donville, PE
TTL Associates, Inc.
www.ttlassoc.com
The views or opinions expressed by me are my own and do not necessarily reflect the views or opinions of my employer.
The NAVFAC DM 7.01 has some general properties of different materials.  Most geotechnical/soils engineering texts do as well.
