Multiple 'split-line' projections
Is there a way to make multiple 'split line' projections?  Patterning a single split line occurence doesn't seem to work.  And you can't make multiple splits to the same body.
RE: Multiple 'split-line' projections
Sure, just make several (several features).  Works fine.
If you have linear splits, simply connect the sketch segments in a serpentine route--run the lines past the body you want to split and join the segments to make a single serpentine path, like a radiator coil.  Multiple face splits with a single feature.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
