Simple Beam SAP2000 Results Do Not Match Hand Calcs
I am trying to model a simple beam (Lenght = 40 ft) with uniform horizontal load of 8k/ft. The supports at the end of the beam are pinned connections.
I model this simple beam using Plan Frame in the Analysis options.
The values of the reactions at the supports of my hand caluculationis and SAP 2000 agree. V = (w)(L/2) = 160 k.
However my moments do not agree. My SAP 2000 results are showing a moment of 1066 k-ft at the reactions, which should be zero.
I would really appreciate if someone can give me some advice one what might be going wrong here.
THANKS
THANKS
RE: Simple Beam SAP2000 Results Do Not Match Hand Calcs
But I am still trying to figuere out why this momement diagram got shifted down.
Could be that you simply have included self weight without knowing you have done that.
Best place to start is simply try to rebuild the examples given in the software.
I was changing all the roller restraints to pin, but leaving the pin (left reaction) how it was since I thought it was a pin. But I did not know that the pin was restraint against rotation. Once I remove the rotation restraints everything worked out.
THANKS
