Hydrogen Sensor
Hydrogen Sensor
Looking for a comercially available, econimical H2 sensor that can detect up to 20,000 ppm either in air or a vacuum.
Also be operational from -40deg. C to +55deg. C. Other gases would be Acetylene and Methane if possible.
RE: Hydrogen Sensor
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
