envelope size
envelope size
How to align reference dimensions to a particular directions?
I have a quite irregular assembly (so, I can't use the sketch). I need to show the envelope of the assembly (a concept design) aligned to the 3 main axis.
If I use a reference dimension, it will show the direct (shortest) distance between the two objects. I need, instead, to show the dimension along x, y, and z.
Any help welcome. Thanks in advance.
p
p
RE: envelope size
See also MinBBox from http
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
