ACAD 2005 - EXCEL PDF PROBLEM
I AM PASTE LINKING AN EXCEL FILE IN AUTOCAD AND EVERYTHING IS WORKING FINE (APART FROM IT SEEMS TO UPDATE ITSELF WHEN IT CHOOSES). HOWEVER THE PROBLEM IS PDF.
I AM THEN PRODUCING A PDF PRINT FROM AUTOCAD WHICH GOES FINE APART FROM I GET A NUMBER OF VERTICAL LINES OVER THE EXCEL SHEET (NOT THE WHOLE PLOT VIEW). THESE LINES DON'T CORRISPOND TO COLUMN CELL LINES IN EXCEL AND ARE NOT VISUAL IN AUTOCAD SO PRESUME ITS A FUNCTION OF THE PDF PRINT (WHICH WORKS FINE WITH NORMAL DRAWINGS).
