Disconnect Switch Selection
Hi, I'm not sure if this is the right place to be posting this but I was wondering if someone could lay down some general guidelines to keep in mind when selecting a disconnect switch for a PLC panel.
For example, I have to select a disconnect switch for a Panel that has a MicroLogix 1200 PLC, a motor (12.4/9.5 A), and 4 heaters (220V 300W each).
Anything you can add would be a great help. Thanks.
RE: Disconnect Switch Selection
Gunnar Englund
www.gke.org
External or panel mounted (interlocked?)
How often it will be actuated
Compliance with Lockout/Tagout
Enclosure type (suited for environment)
Susceptibility to damage (believe me, it will happen)
Chapter 5 covers disconnects.
ht
David Baird
Sr Controls Designer
EET degree.
Journeyman Electrician.
