Flattening IGES surface
Any ideas how to do this - surely somebody must have solved this already? Does it require Pro/SHEET METAL?
The IGES surface is a toriod - curved uniformly in two directions, with a different radius in both directions.
Cheers
Dave
Cheers
Dave
RE: Flattening IGES surface
Flatten Quilt might give you an output but I think I'd just go with concentric circles offset by the section circumference.
Worked perfect mate - a few seconds work with your guidance.
Further proof that with the correct tools for the job, it takes a mere fraction of the time!
Thanks a lot
Dave
