Deaerator (Seawater) Tower Coating Failure
Fluid: Seawater
Capacity: 46,000 bpd
The water Injection System consist of a Deaerator Tower, Coarse and Fine Filters. In the past we have been using glass flake lining and Monel/Super Duplex Stainless Steel internals. However, we are experiencing repeated failure of glass flake lining and epoxy coating in this service (3rd time now).
We have heard different versions from Vendors, some saying that the internal coatings have been successfully used in other project and that it is strange failures should only be with us.
Can someone please share their experience?
Will SDSS cladded vessels be the best solution?
Thanks.
Fluid: Seawater
Thanks.
RE: Deaerator (Seawater) Tower Coating Failure
The best solution is probably the most economic one for the service life of the installation.
http://www.welding-advisers.com/
