Pro/INTRALINK question
Whenever I add an existing part to a new assembly, the part status (in workspace) changes to "modifed". Why does this happen??? I'm not actually modifying the part. This also occurs when I modify text or something in a drawing. Has anyone experienced this? Is there some setting that needs to be changed or checked during Intralink set-up?
Thanks for your help.
RE: Pro/INTRALINK question
From my understanding, you have modified the part, you have modified where this part is used.
Tofflemire
David
