Interview Questions
Interview Questions
I'm going to be interviewing candidates soon for a licensed civil engineering position with the County government I currently work for. I'm seeking some creative interview questions that help gauge a persons qualifications, experience and ability to work effectively in a team environment. The person will be responsible for a variety of civil engineering projects (water, sewer, stormwater, solid waste). I can provide more detail if it would help.
I want to weed out the "paper tigers" and find someone qualified who can work well in a team environment, mentor and provide leadership to junior staff, and (ideally) bring both public and private experience to the table.
I want to avoid a full hour of "So, tell me about yourself" and "Why do you want to work here?" type questions.
Also, any ideas for "exercise questions" that can demonstrate experience?
RE: Interview Questions
Try a practical work example, ask them to actually do some task typical of the job. Survey, design, inspection etc.
If its a managerial level position have him give a (mock) subordinate a work assignment, then give him a partially completed work product that is not correct and off the mark and see if he can find it and how he responds and gets the subordinate back on track.
The Canadian federal government once had a “in basket” test. There was a pile of written material and correspondence to be looked at and the candidate had to go through it and draft appropriate responses to the material. There was simply too much material to be covered in the time allowed and the trick was to do a triage to the material. If you did that you found that there was some correspondence at the bottom of the pile that made the stuff at the top redundant and there was just enough time to get through most of it. Miss the stuff on the bottom while working on the stuff on top and you were lost.
Try role playing, have people act out the various roles and see how the individual responds. eg. Hold a mock meeting with people playing a contractor, an elected representative and a local land owner affected by a construction project. The candidate can be the Project Engineer and you can test his (or her) responses to the conflict and how he works at reconciling the various concerns.
Take the candidate to the break room at coffee time and see how he interacts with the potential co-workers. They may even be primed to start a discussion on some topic to see how he fits in.
Take him into the shop. Check to see if he looks around for safety gear (hard hat glasses, hard shoes etc.) before entering the area. Does he know enough to at least check on the local requirement for this or will he blindly walk in wearing his good suit and dress shoes? Does he look around for safe means of egress or does he walk under the crane?
Use your imagination and have fun. Interviews do not always have to be formal and stressful. Setting up a realistic interview with role playing and tests is a lot more work than “Tell me about yourself” questions but is a lot less work than correcting a hiring mistake and starting the recruiting process all over again.
Rick Kitson MBA P.Eng
Construction Project Management
From conception to completion
www.kitsonengineering.com
Chris
Systems Analyst, I.S.
SolidWorks/PDMWorks 05
AutoCAD 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
I believe that there is no substitute for the real thing. I believe that it is nearly imposible to get a true picture of whether someone will work out in an interview because there are so many factors that affect whether the candidate will work out.
In my experience, even if the person is a perfect candidate, and you figured this out during the interview, they may still not work out.
I have experienced instances where the perfect candidate was rejected by his/her work team. If his/hers peers won't work with him/her, you will have a far bigger headache.
For example, if working as a leader in a team environment is important, ask something like "Tell me about a time you had to manage other team members to accomplish a task." Then listen. Most times they give you half answers, almost always initially they are hypothetical. Keep pressing them to think of real examples. Don't let them off the hook. Sometimes it is extremely uncomfortable! It's easy to give the canned answer to interview questions, tougher to give real examples! If they can't come up with real examples, they may not have the experience you're looking for.
Having been on both side of this interview technique (after taking some HR courses on this technique as a hiring manager, my first job interview was using this technique on me!)
You also have put a lot of your time into the hiring process and if you reject a guy on probation in 3 months then you are still at square one with no employee in place starting to become productive.
Then all the candidate search costs have to be paid out again etc.
Always better off to get the correct hiring decision made in the first place.
Hiring for other positions does however allow you some latitude.
I worked with a contractor that hired anyone who came through the door and looked healthy and appeared to have at least minimal intelligence and coordination. The position for entry level was night shift on a jack hammer doing demolition and other menial tasks.
The people were hired for 3 days at minimum wage and they were told that if they were late, lame or lazy then they could be fired at any time during the three days. If they worked hard they would be hired on for the job and given a raise to about 50% over minimum.
Some guys lasted an hour some were picked up permanent by the company and moved to the next job. Recruitment costs were essentially nil.
I agree with your response. It is best to get the correct hiring decision made in the first place.
The hard part I see is the execution - how to discern everything that you posted during the interview process. I am not aware of any 100% proof method to achieve this - hense, the probation period.
Would you agree that there is no substitute for the real thing? If not, what is a good substitute?
Sort of like dating before marriage.
Skills can be learnt but aptitude, persistence and integrity are in a person's character and are far more valuable.
I like Rick's idea of the role play. BUT...
I've been on the receiving end a couple of times, in both cases they got all the applicants around a big table and set us a task. First time, when I was a kid, I was completely bamboozled by the older, more experienced, applicants and basically contributed nothing. The second time, recently, we were given the usual silly project (design a car for the moon) and left to it. Since I've spent ten years sitting in teams designing silly things of various types, it was very easy to work out how to approach the problem, and I passed easily, even though I had backed the 'wrong' design and had to compromise (evil grin, yes you can game-plan).
However, in neither case did I think that the right people were picked by the process. Many good engineers are somewhat introverted, and many are a bit slow to get going. Dropping them unprepared into a management style stoush allows the bright big-mouths to shine. Neither job was really looking for bright big-mouths.
The best interview series I did gave me a free hand. If the aspplicant seemed reasonably OK we'd go for a wander around the lab, I'd tell them (some of) what was going on. If they grasped the opportunity to start making sensible suggestions, on they went to the next stage of interviews. If their reaction to the work in progress was out of line with their claimed experience, well, seeya.
Cheers
Greg Locock
The Decision Maker was kind enough to later explain that it was staged, and I didn't get the job for lack of "conflict resolution skills", i.e., I didn't jump in and stop the argument.
I didn't, because I was curious to see who would prevail and how, and I had come from an environment where verbal conflict was common and even encouraged, and I didn't know which of them might be armed.
It's the only such interview that I've experienced or heard of in four decades in the job market. I have to admit that it's an effective way to screen for 'take-charge' types, if that's what you want.
For technical people, I pose questions by sketching out a problem, and asking, not for equations, but what quantities need to be supplied to make the equations work. I never reveal the answers; I just record their response and pose another question. Real technical people think we're just having a nice chat; phonies come away shaking.
I have no idea how to select for team players in a short interview. Maybe have somebody pop in with a typical "government work" question, like, "I want to raise the roof on my garage, and put a dance floor up there, and I have little money; what else do I have to do?" ... and see how they respond.
Mike Halloran
Pembroke Pines, FL, USA
My apologies. You are correct. I took a look at your industry, and mine is very different.
In most industries, in most markets, my suggestion probably is not very good.
As I still think there is no substitution for the real thing, I will modify my suggestions with a few caveats:
- the candidate needs to know upfront that it is a 3 month probation
- the candidate is willing to leave their present position and take the risk, or is currently not employed and is willing to take the risk
- the candidate is local
- a very liquid market
In my current industry, here, the market is very hot, and movement amongst employer is very common. Many people work for 3 months, or less, and move onto a better paying position/company. Many don't, and stay. It depends. Poaching is not unheard of.
Most of my peers are independent contractors, and go contract to contract. Often the contract is for a project. Often, it is fixed term (e.g. 6 month).
Hence, it is relatively easy to structure a 3 month contract with option to extend.
I have within the last 3 years, signed a contract that:
- is for 4 months
- included a provision that both sides needs to give 1 month notice to break the contract
- included a signing bonus
- included a "contract fulfilment bonus" (if I stayed for the full 4 months, I get the bonus)
I have also signed a different contract for 17 days.
I agree with you, it is best to get the correct hiring decision the first time.
A guy who is really into fishing may be very organized - you don't want to come to a big bass tournament without being prompt and properly prepared. I work with a guy who is a skydiver - he is very organized and precise - you don't jump out of a plane on a whim! We use him do our design validations and design reviews.
Someone who has been in a team sport, band, or choir maybe someone who works cooperatively in a group. Team sport people may develop into coaches and group leaders. A track runner may tend to compete with everyone and not be group oriented.
The person deserves your full and undivided attention.
I would not pay a lot of attention to hobbies. A person may pick solitary hobbies simply because after a day at work in a team atmosphere they want to relax alone.
I never placed sports of any kind in school. (Born premature near the end of the calendar year and so was always the physically smallest in my class.)
However I still consider myself a team player.
Mike
The process that you attended with the staged argument did not eliminate you because you were somehow an inferior candidate, it eliminated you because they wanted someone who would resolve conflict and not allow arguments to exist.
Look on the bright side, your background would not have made you a good fit for the company. The process saved you a lot of time and grief.
I was conflicted about it because the Decision Maker was a stand-up guy, of the sort anyone would like to work for. I wonder if he survived.
Mike Halloran
However, in my current job I think I am making a positive contribution to the company, and I get along with everyone from the owner down to the guys in the shop. Thankfully I was not subjected to any of those interviews described so far, or I would have been judged not qualified for my own job.
So, as a professional interviewer - I know it's not fair - but I answered those open-ended questions, honestly and completely, but in the back of my mind, I always thought, "this guy/girl doesn't know what he's doing."
I tried to explain to her that she wouldn't be spending all of her time teaching me how to do things in CAD or design, and I was well justified for the money I was asking for.
2 years later I was giving a big presentation to some companies at the college and she happened to be there. She didn't remember me and offered me a job on the spot. She explained she was having a hard time finding good people who knew what they were doing.
I laughed at her and told her that I interviewed with her 2 years ago and explained that because of how that interview went I could never work for her company.
I look back on it now and am extremely glad I didn't get that job, it probably would have set me back at least 2 years in my career.
The second thing is to check the applicant's references.
This will get rid of 80% of the applicants. After that you will have time do a thorough review of the remaining 20%.
great story! thanks
Chris
AutoCAD 05
FAQ559-1100
FAQ559-716
Hobbies/Sports/Interests - I don't read too much into what interests a candidate has, as long as they demonstrate they have interest in something beyond the end of their nose. I travel too much to be involved in organised team sports - I can't be relied on to be there for training or game time and it would be unfair on potential teamates, so my main form of steam blowoff is running wherever I am. How does that translate to my potential level of contribution to the team at work?
LewTam Inc.
Petrophysicist, Leading Hand, Natural Horseman, Prickle Farmer, Crack Shot, Venerable Yogi.
If you are checking references ask each reference for someone else who worked with the applicant and knows their work. Then ask the second level reference the same questions. By the third level reference you will get the actual truth about the person. I learned this from being a reference for several security clearances and being interviewed as part of the security clearance of others.
I know of some companies that are only allowed to confirm length of employment and the general duties assigned, no information of performance allowed.
The only question that I will ask a reference that actually tells me anything is “Would you re-hire this person for their old job?”
It’s the length of the pause that is most telling, not the actual resoponse.
It happened today. I agreed to a low rate for a low level job, just to keep the wolf from the door, and was then granted an interview. As the interview progressed, the scope and responsibility of the job expanded.
I'll start tomorrow at the agreed rate, and see how it works out. Maybe they'e okay guys, but the experience left me feeling, er, pre-abused.
Mike Halloran
Mike
You should have been upfront with them in talking about the scope of the position being more than the initial scope.
You could still have taken the job for the agreed salary but left open the issue that the position was more than initially described. Now once you start the job and come back asking for more your new employer may feel that you were using them.
At the very least you have excluded further salary discussions for 6 months or more.
Good luck on your new job
That seems really unfair.
They asked you to agree on the price you will pay for the car you are going to buy - before you coming into the showroom?
I don’t see any problem agreeing to at least a salary range before the interview.
After all it costs both parties time and money to hold the interview in the first place.
Not job interviews but I have gone through the selection process as a consultant and as a single practitioner its much like a job interview process, only to find at the end that the company will not be anywhere near my fee requirements.
I have even had a fee offer less than bare salary costs, less than they would have had to pay an employee. When I pointed out to them that they were offering far below the going salary let alone anything to cover overhead, insurance etc. I was bluntly told to take it of leave it. I simply got up thanked them for their time and left. I later heard that they tried to manage the project themselves and ended up with a real mess on their hands. Unfortunately due to not having at least a acceptable range in discussion at the start cost me several days plus expenses.
However if the scope of the job changes dramatically then the salary range should also change. Accepting a change in scope without discussing the possibility of a change is salary is dangerous to both parties.
I get the impression that Mike is going into the job with the expectation that after proving himself he can ask for a raise and since he has proven himself in a higher position than discussed the employer will be all too happy to grant it.
Wrong, they will feel that they have an agreement for the expanded work at the lower salary and will feel betrayed that they are being asked to implement a substantial raise after only a short time. They may not even realize that the scope of the job expanded, they may feel that they simply fleshed out the job description during the interview.
In any case it leaves open the real possibility that there will be a parting of ways and hard feelings in about 6 months.
The only one I've actually used when interviewing for my company is "How would you move Mount Fuji?". Most of our positions are project manager type so I'm looking for the person to respond with other questions like "How long do I have?" or "Is there a budget limit?". Basically things that show me this person can break down a huge task into managable pieces and coordinate resources to get things done.
The only other insight I've gained through the dozen or so interviews I've conducted is that I try to hire for motivation, initiative, character, ethics, etc. rather that hiring for particular skills or project experience. Presumably the person was granted an interview in the first place because he/she has a resume that communicates skills and experience. Now I want to find out about other traits that came into play during that experience. Unfortunately these other traits are also the hardest to interview people for...
I offered to fill in until they can find a "CAD Operator" who understands what the lines represent. We agreed that when they find such a person, or I find a job that pays better, I'm gone, no hard feelings on either side.
Mike Halloran
