Node numbering
Node numbering
Hello everyone,
I am working on an FE model whcih has a global model which then drives a local model. I am coming up with an error which ive never seen before, as when I run the local model job it says that
"the node numbering might not be correct for element # instance 'name'"
where # is an element in instance "name". this error is repeated for every element in that instance. I must say taht this instance is of a part whcih contains cohesive elements only. Why does this error occur??
Thanks for your time and help,
Andrea
Andrea
RE: Node numbering
If you are using ABAQUS/CAE, take a look at your MODEL->Keyword editor> Model_name. Make sure your are using the right element for your cohesiv region.
RE: Node numbering
andrea
