Can NOT get Cut List Table Proprietes
Can NOT get Cut List Table Proprieties - even when "going around" that is geting the column proprieties and then clicking on Table Proprieties.
What am I doing wrong ?
RE: Can NOT get Cut List Table Proprietes
Forgot to add: SW2005 SP4.0, Windows XP.
It used to work in the past - now it would not <sight>
jacek0841,
If I understand you correctly, if you left click on the cut list table in a drawing, you do not see the table properties button in the property managaer tree?
Regg
Yes. I can "hover" over the coumn and get column/cell properties (in the mgr tree) and other stuff, but clicking on table properties "button" just closes the window in the mgr tree.
I tried to work around and recreated the Cut-List on the dwg. BTW, there are 9 dwgs, because there are 9 configurations of the weldment.
Now I can get the cut list TABLE PROPERTIES but somehow when displayed in mgr tree the cut list table CONFIGURATION is wrong and can not be changed although the cut list table displays PROPER length of items - that suggests it reflects the actual configuration of view to which it is attached - just the config in the mgr tree it's wrong. BTW, the configurations in the SLDPRT are made by the Design Table.    ??????
