ACCEPTABLE VIBRATION LIMITS IN BOILERS
What are the acceptable limits / standards for vibration caused by the combustion process, or any structural resonance in fired heaters / boilers.
RE: ACCEPTABLE VIBRATION LIMITS IN BOILERS
As far as I can tell there are no actual limits on pressure vessels for vibration.  The problem is that you can induce a fatigue type failure but you can predict how that would affect your equipment by using a standard S-N curve where N would be the number of vibrations.
On the other hand follow this thread to see a previous discussion about piping vibration.
http://www.eng-tips.com/viewthread.cfm?qid=118684&page=1
Good luck,
Ron Frend
http://www.predicon.net
