Automated Message Player
I am looking for an automated MP3 player that will play a message when a contact is closed. I plan to use it over a stores intercom system to play several messages when a relay is thrown. If the device can be intergraded into a board design that would be even better.
RE: Automated Message Player
How many do you need?
<nbucska@pc33peripherals.com> omit 33 Use subj: ENG-TIPS
Plesae read FAQ240-1032
TTFN
Note: The reason this was posted twice is because someone mentioned that the question was better suited for this forum.
MP3 needs costly processing -- unless quantity is huge.
It may be more economical to digitize the raw audio
and do it with brute force -- memory is cheap and
getting cheaper.
Fix message or changeable?
RAM connected to a DAC. For recording an existing PC
could be used with some additional circuits.
a computer CDROM to play audio tracks (not mp3)
elector magazine did one- you could select the track to play
