Modeling Nonstructural Components
I am trying to model nonstructural components; hence mass that is additionally attached to the frame. I want to attach the mass to the frame with a stiff link. Hence do I draw a 2-joint link in which I specify high stiffnesses (how high?) in the translational degrees of freedom and then add additional mass to the node that is attached to the frame with the link element?
RE: Modeling Nonstructural Components
Draw a joint where you want to assign your load and/or mass, then select the joint along with the joint(s) you want to connect to, and Assign a joint constraint. Probably Body type constraint. In SAP you can convert any load cases into mass
If you are not doing dynamic analysis, you simply input the load as a joint force. Do you want to apply your load/mass along the length of the frame? If so, then draw the special joint on the frame. If the load/mass is offset, then draw the joint in space offset from where you want to connect, then assign joint constraints. If you draw special joints in space, you can draw anywhere, then right click joint to modify x,y,z coordinates
