Zero line weight?
Zero line weight?
Anyone figure out a way to create a zero line weight? This is for photo etching TIF file generating. What I've found is that the fills will go to the outside edge of the line weight. And the smallest line weight SW lets you have is .001968504 and although this is very small, it still makes the image larger than the actual. If I can't get this to work, I'm back to porting out to Acad to get the results I need, then into Corel to be able to have the graphics company use it. Thanks.
John
John
RE: Zero line weight?
John
Chris
Systems Analyst, I.S.
SolidWorks/PDMWorks 05
AutoCAD 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
