Vibration table fixturing for ESS screen
I'm in the process of trying to clean up and improve an existing vibration table and test processes with my current company; they would like to reduce the cost of implementation and testing by using existing material and equipment. The table that we have is a QRS-100E, which utilizes a vacuum system to keep vibration fixtures "sucked" down onto the table. I was curious if anyone might be able to provide information or insight on an acceptable rubber material sufficiently "sticky" to keep the fixture from sliding around, and sufficiently "stiff" to prevent over damping of transmission of vibration energy to parts. Our ESS vibe levels are from 20 Hz to 2000 Hz, and PSD ranges from .01 to .04 at 6.1 grms.
David McCann
David McCann
RE: Vibration table fixturing for ESS screen
