Bulk item parameter change
(Pro/Wildfire)
I'm attempting to change a parameter of a bulk item but I'm not even able to select it.
Here is what I'm attempting: In assembly mode, I select "Tools", then "Parameters", then I select "Part" (from a drop-down). Then the parameter screen goes away and I'm prompted to select the part. I assume the only way to select the bulk-item is from the model tree. When I select the part from the model tree, nothing happens (I'm not able to select it). So I can't continue until I successfully select the bulk-item.
Any suggestions?
SrG.
Any suggestions?
SrG.
RE: Bulk item parameter change
Good luck!
<tg>
You are a good carpenter (You hit the nail on the head).
That was exactly what I needed.
SrG.
