lookinf for a way to maximise the ansys classic screen on windows
i use ansys classic multiphysics. The screen of ansys on the active display area where modeling and meshing is done is coloured black area with a white rectangle around it. To the right of the rectangle is some free black space not active. i would like to pull the white rectange boundary line across the full width of the black screen area and maximise the active modeling area within. is there a command i cand use to do this??
RE: lookinf for a way to maximise the ansys classic screen on windows
http:
I hope it helps.
Alex
That visualization is due to the WINDOW LAYOUT configuration. Try:
Utility Menu >PlotCtrls >Window Controls >Window Layout
and then for WINDOW1 --> FULL instead of SQUARE.
Of course you can also choose other window configuration (2 or more windows for example).
I hope this will help
