Design table driven equations.
I think I have seen this but I am having a syntax issue.
For example, I have an equation; "numholes 1"=4 in an assembly. Can I change that number four using a design table and what is the syntax in the design table to do so?
That equation controls the hole pattern in four parts where they all bolt together.
RE: Design table driven equations.
or
With the DT open & with the next available cell highlighted, double click on the hole pattern (int the FM) to show the qty in the graphics area, then click on the qty to insert it into the DT.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
thanks for the suggestion, I ended up putting a dummy part in and putting the hole patterns on that part at the assembly level. Then I linked the values of the assembly hole patterns to the part hole patterns with equations.
No equation linking required and quantity and spacing updates accordingly.
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2005 SP5.0 on WinXP SP2
SolidWorks 2006 SP3.0 on WinXP SP2
Picture a box that bolts together at the corners, say there are a minimum of three bolt holes at equal spacing. As the box gets taller, more bolts are needed, the distance between the holes is constant. As it gets taller more holes are popped in.
Constrain the "fill area" so that it changes with the part length & the pattern feature will automagically populate the area.
The only woraround (which you may have found) is to create some sort of assy feature and use that dimension to control the pattern in the DT. I've done it with a reference sketch. Just added a line with a dimension that acts as the "pattern" number. Then link your equations to that.
After you're done, fill out an enhacment request for the Global Variables to able to be controlled from a DT and configurable.
Jason
