Rectifier fuses
Rectifier fuses
It may seem obvious that a rectifier fuse is used with rectifiers. But why? It seems that the curves for rectifier fuses are very similar to "one-time" fuses. We have a PT setup which was designed using old KAW type fuses, and they are labeled "rectifier fuse". What makes a fuse a recitifier fuse?
RE: Rectifier fuses
RE: Rectifier fuses
Thinking about it, that does make some sense. Thanks for your info, GordS!!!
RE: Rectifier fuses
RE: Rectifier fuses
http://www.bussmann.com/library/docs/Spd.pdf ‘high speed fuse application’ has some general information.
RE: Rectifier fuses
RE: Rectifier fuses
Thanks.
RE: Rectifier fuses
http://www.bussmann.com/library/bifs/1014.pdf
Shawmut lists ATDR as their equivalent.
RE: Rectifier fuses
RE: Rectifier fuses
