dB in vibration PSD specification
3
 Recently I received PSD data input.
 In that PSD input 5 to 20 Hz, some constant PSD input was specified. Then between 20 to 200 Hz, the input was mentioned as negative slope of 6dB per octave.
  To my understanding 6 dB per octave indicates the vibration level will reduce half per doubling of frequency (Octave).
Say at 20 Hz, the PSD level is 'x'. Then at 40 Hz it is 'x/2' as per 6dB per octave concept.Whether am I right?
 If not pl. correct me.
 Is there any specific reason to charactize the input with slope of dB per octave.
 Thanks for going through this thread.
 Logesh.E
RE: dB in vibration PSD specification
Yes, you have it right. 6 dB/octave roll off is a typical first order response.
I think you'll find it gives constant energy per octave as well.
Cheers
Greg Locock
Thanks Greglocock.
I got it.
Logesh.E
Hi Tom,
  Thanks for posting the conversion utility.
 Based on the conversion utility,the PSD value reduces quadrupally.
 Earlier, I calculated the conversion based on the following formula,
  dB = 20 log (X/Xref)
 With Xref = PSD value in G^2/Hz. Therfore I thought X = 2*Xref (For positive slope of 6dB per octave).
whether the above formula is right!
 If not, Can you specify the formula!
 With Thanks and Regards,
 Loganathan.E
