unhandled access violation error
Autocad 2002. Open drawing,select plot device and paper size, window area to be plotted, and when I try to plot or preview complete plot and I get the Unhandled Access Violation Writing 0x3EE07FA5 exception at 332BE76BH error.  Answer error message windows and then Autocad closes.  Uninstalled and reinstalled full program with same results.  Can window small areas with no problems and large areas with no problems, but when I window this particular area that I want to plot I get the error message.  I copied the file to a different machine and I get the exact same results except for the addresses are slightly different that those listed above.  Any help would be appreciated.  Thanx,  John
RE: unhandled access violation error
If it's the same drawing giving you problems then it may be a corrupt drawing file. I'd try auditing it. If that doesn't help try wblocking the drawing, then try and plot the new drawing.
Acad2005, Terramodel
