spline length
spline length
On which manner is possible to measure length of spline (in sketcher) or 3D spline (in Generative shape design). I mean what length of that spline would be if spline is straighten.
For example I have some part made by rib command, it is not made in Sheet metal design so I can’t make unfolded view in drafting and measure length of that part.
RE: spline length
You can create a parameter called "Length" and
the you add a formula. Write length() and place the cursor between the parentheses and double-click on the spline.
My example... length(`Geometrical Set.1\Sketch.1` )
RE: spline length
RE: spline length
RE: spline length
