looking to convert GDS II file formats into dxf for ansys
hello
i am looking to convert GDS II file formats into cad or ansys format. I heard of a program called Linkcad which cand do this. Im having problems with the demo version and to purchase it is really expensive. Can anyone suggest another way or haeva working program in which i can make GDS II files compatable with ansys Such as DXF so i may import them??
thanks
thanks
RE: looking to convert GDS II file formats into dxf for ansys
See FAQ569-1083 for details on how to make best use of Eng-Tips.com
Anyway i will keep playing around with it, i have been trying all of the above named formats that you mentioned. I heavily use solid works and inventor however the reason i was looking at link cad is that when i bring in a sinple 2d drawing in iges format for example some of the paramerter and lines get distorted and are not where they should be. I have found in the past the i would spend as much time tidying up these errors as i would just drawing a new part itself. i was really looking at quick way to bring alot of 2d drawings from the gdsII format.
