Help with SW Display
Have been using Using SW 2006 SP2.1 for a while now.
Win 2000 SP4
Dell Precision 360 3.2
1GB Ram
NVidia Quadro FX 1000 Driver 2/24/05 Ver 7.1.8.4
Friday all seemed normal with my system. I Shut down for the weekend. This morning I booted up and I noticed my feature manager background was a darker grey color than normal and hard to see and the RealView Graphics Icon is greyed out and not selectable. Any Ideas?
Tom...
Win 2000 SP4
1GB Ram
Tom...
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
RE: Help with SW Display
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
Has windows done an automatic update? Check that it hasn't altered your graphics card driver. Check that the cards application setting hasn't been altered.
Can you re-seat your graphics card?
Can you swap out your graphics card for another of the same kind?
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
I'm not sure if any automatic update has occured.
I have not re-seated my graphics card, but I'm running dual Dell 2001FP monitors @ 1600 x 1200 and all seems OK.
No I do not have any other graphic cards.
However, NVidia has a Dualview Property manager with a Custom OpenGL application setting, and SolidWorks is selected. Everything else seems normal as far as video settings.
I suppose I could uninstall and re-install the video drivers.
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
When you rotate the assembly is it choppy? Where does the computer sit on the desk or on the floor? If when rotated the screen is choppy then I would check to see if the video card is covered with dust bunnies. I had a video card fail because it overheated due to dust bunnies.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
If this doesn't work, I guess reinstall the video drivers is next. If that doesn't work then maybe re-install SW...
thanks.
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
Make sure the Show Updates option is selected.
You can then check at MS site (using the KBXXXXXX number) what the latest hotfix installed affects, and if necessary uninstall it.
I recently had to do this for a problem with Outlook. The hotfix did not install properly, so had to uninstall & reinstall it.
CBL, I went on the MS site with the KB number but I really don't feel comfortable uninstalling a HotFix. I couldn't even find a date in my Control Panel as to which Hotfix was the latest installed.
Just a sanity check,
If I reinstall SW is 2006 SP2.1 all inclusive?
I will completely uninstall SW
Run Registry Mechanic
reinstall from my disks
Then apply SP2.1
am I missing anything?
thanks, Tom..
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
As a matter of interest, what are the latest KB's installed.
KB329115
KB823182
KB824105
KB824141
KB824146
KB825119
KB826232
KB828028
KB828035
KB828749
CBL, I dont know which ones are the latest unless it just goes by the sequential number.
thanks for your help,
tom..
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
Alternative to try before reinstalling FAQ559-507
How do I Repair or Modify of a SW Installation? FAQ559-908
How do I do a clean uninstall & reinstall of Solidworks? FAQ559-488
However, I don't think it's a SW issue. It sounds more like a driver issue, or your card may be breaking down & need replacing.
I had a quick look at the KB's but could not see anything obvious related to graphics.
Again, thanks so much
tom...
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
FYI I was just about to start a deeper diagnostic using the FAQ info you suggested in your prior post, but just for the heck of it I lowered my video resolution from 1600 x 1200 to 1280 x 1024 and sure enough that brought back my hardware acceleration. So then I figured I'd put it back to 1600 where its been for the last year, and wam...it works also. Go Figure, something in my system probably a hot fix as you suggested changed something that caused the conflict. I guess only time will tell if I see this problem again. Hopefully its just another one of those unexplainable computer glitches.
thanks for all your help
tom...
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
