3 ball versus 2 ball crushload tests.
Does any one here have experience of crush testing of large bearing balls ?
1) Im setting up a specification for the purchase of large (say 50~70mm) carbon chrome steel balls and want to include a strength test. I see some ball manufacturers qualify the strength of their products using a 2 ball compression test, while some put 3 balls in compression. If the same balls were tried in both, which test is likely to give the higher result and by how much ?
2) What metalurgical parameters are most influential on ball crush strength ? Hardness, homogeneity of material structure, or perhaps material purity ?
Your comments will be appreciated.
Gerry
Gerry
