Silicone adhesion to fabric
I would love to hear from anyone who has practical experience of adhering a soft RTV silicone to fabric. We are designing a prosthetic device, tubular in shape. Once we have cracked this we are 'home and dry'
Appreciate any help!
RE: Silicone adhesion to fabric
Regards, Wil Taylor
Like using some kind of bracket or socket?? But most important, it must not be obstrusive to the wearer.
Thanks for any comments
Speedy
John Schrock
www.glubie.com
I have a urethane/polyester/nylon fabric laminate which we sonic weld at the seams, which forms a channel about 5/16" wide and 1/8" thick. Material is elastic and will be in water now and then also in sunlight. Storage temperature of fabric could reach 125 F at times. I need a UV resistant, low modulus, high elasticity, soft, low VOC, low skin irritation sealant to fill that channel...maybe a base cure urethane? or? Any off the shelf products you might suggest?
