CAM in UG
CAM in UG
I have UG NX with the Manufacturing Module. What is the best way to learn CAM in this software?
About 10 years ago, I programmed a cnc plasma in G-Code, but that is the extent of my experience with CAM. I utilize UG to design factory automation equipment.
RE: CAM in UG
Use CAST or i.get.it.
Ben Loosli
Sr IS Technologist
L-3 Communications
RE: CAM in UG
I haven't installed CAST yet because the doc CD crashes my machine for some reason.
RE: CAM in UG
With little or no CAM experience as you say, NX CAM will not be easy to pick up cold.
The CAST training is good if you have someone who is familiar with CAM and how it works but someone like yourself you are in for a good deal of training and time.
Welcome to NX CAM
RE: CAM in UG
Take care...
RE: CAM in UG
