formula for pressure in a pneumatic cylander
Good day all,
I need the formula to calculate the force applied to the shaft of a pneumatic cylinder. any help would be greatly appreciated.
RE: formula for pressure in a pneumatic cylander
please take a look at these figures and see if my calculations are correct. I have a cylinder 4" dia. apply 30psi and I get 376.8 pounds of force?
Be careful about giving these guys too much information, they just may start running with your project, and take YOUR fun out of it
Use a catalog for the selected actuator to find tables that reflect the forces available at different supply pressures and different stages of travel. Compare the forces or torque applied agaainst the forces or required to start and stop the load (open or close the valve, etc.).
John
