Pressure Regulator
Pressure Regulator
Pressure Regulator
I am using 800 psi helium overpressure to feed liquid nitrous oxide into a system.  I need to find a pressure regulator that can be set for 800 psi and maintain this pressure for the entire cylinder without needing to be reset.  I am currently using a typical one stage high pressure cylinder regulator.
If anyone could suggest the best type of regulator and where I would be able to buy them that would be great.
Thank you
RE: Pressure Regulator
Take a look at Tescom or Cashco regulators.  We have several in high pressure helium service.  Make sure there's a relief valve downstream if downstream components aren't rated for your 2400 psig cylinder pressure.
Larry
