Trip Coil Design
Trip Coil Design
Trip Coil Design
Any ideas on a design for a AC trip coil that has to release
a 2 lb. load.
Asa the spec calls out , they want an AC shunt trip to work down to 13VAC on 125V P.U. basis, which can also reach 190VAC L-G.
the latch load is around 2 lbs.  Therefore, any trip device must develop in excess of 2 lbs of force to trip the breaker.  They do not want to use a DC coil, any thoughts on a way to do this without having an extra device in this circuit.
thanks
RE: Trip Coil Design
Any way you can charge a capacitor off the line side and use that to fire the trip coil? Calculate the resonant frequency and spec it as an AC coil with a 1/2 cycle normal operating duty.
