multiple selection in V5 like in V4?
For multi selection user does *element type for various elements in CATIAV4. (eg. *pln, *color). Is there similar multiple selection command in CATIAV5? (Except edit+search, tools->hide/show-> all planes etc)
RE: multiple selection in V5 like in V4?
Cheers
Jim
Everything is in EDIT+SEARCH
Jim mentioned the Power Input field. (I didn't know that .PLA* would work, but I'll try it) Here's a short list of some of the V4-like selections:
T=point select all points
T=line select all lines
T=cur* select all curves and lines
T=sur* select all surfaces
T=pl* select all planes
T=body select all solids
T=sk* select all sketches
Col=green select all elements with green color
N=*wheel* select element (or part) with “wheel” in name
